1 - 7 of 7 Posts
Here are some photos of the slip on exhaust on the bike. The bike looks pretty good and sounds great. Attaching the exhaust was easy and here are some notes:
1. the mounting bar will have to be bent a little in order to mount with the bracket on the body but its just a slight bend
2. the exhaust just slips on but I used some silicone gasket seal to ensure a good seal, the exhaust collar works but it is just a piece of metal and I think the seal works better
3. I used red threadlock on the bracket on the body and on the mounting bar to ensure that the exhaust does not shake off. I put some on the exhaust collar as well but Im not sure that it wont get too hot for it to fail.
4. I added some high temperature paint to the area around the exhaust in order to match the color of the bike and the color of the exhaust. In my close up photo youll see the paint as it is curing and right now its a darker black that matches the bike, which you can see in the last photo
88133
88134
88135
Thanks J...I have one on order and this was helpful...it looks like your is pointed slightly down and not out at 90 degree angle (unless it just looks that way in the picture angle)....was there any strategic reason you angled it like that?
it was how the bend on the metal mounting bar altered the installation, but also it pointing downward is helpful for exhaust and for noise
What is the weight saving of the Voodoo vs the stock muffler??
Less weight from the Voodoo may well yield more net performance gain than more noise.
its significantly lighter and the acceleration is better, top speed seems the be the same
I really like the look of this. I have been looking for a different option from stock but wasn't sure what I wanted. I like the deep growl/pop I get when I take the stock muffler off, but its too loud for the area I live. Do you have a video of what this sounds like?
Unfortunately I dont have a video and I have already put some scrubbers into the tube to make sure that it is not TOO loud, so I dont have a sample of the original sound.
1 - 7 of 7 Posts
