1 - 20 of 25 Posts
I was starting to get nervous this Spring with inattentive automobile drivers making left turns in front of me. I decided to add some LED lighting front and back to try to improve visibility. Thanks to @explorecaves wiring harness, it was easy to tap into the switched power to add running lights. I added red LED bulbs to my Mutazu saddle bag light fixtures, and some Soyavision white LED lights to my recently added Fehling crash bars. The total package only added 1/3 Amp to the overall current drain. ( I fused the additions at 5 A) The lights are actually brighter than the pics show.
I'm happy with the new look, and we'll see if it makes me more visible on the roads. My wife says it does. Here are a few pics. The Soyavision lights are very inexpensive, so not sure how they'll hold up, but I can upgrade them if needed.
Looking good Prof!
Reactions: Ruby
Great weather today, so I took a 50-mile ride along the Lake shore to Pultneyville....one of my favorites. I think the lights were working. Got lots of double-takes, and even the oncoming Harley riders waved to me. (That's new):oops:
Even better, no one turned in front of me, so keeping my fingers crossed. (y)
Hoping to get lots of riding in this summer. I stay in the country if possible,
Ride safe.
Awesome news on the increased visibility Prof. I have Skene Photon Blasters still in the box for my VFR. They have patented technology on their lights that create a flash or a flicker when the light is presented in someone's peripheral. They are very bright forward-facing too but do not appear to flicker when one is looking straight at them. Anyhow, I had them on another bike and they all but eliminated pull-outs from side roads, parking lots, etc. Really a fantastic product. Just in case you were interested. Your bike looks great and I am glad that the solution reduced the pullouts!
I have Skene Photon Blasters still in the box for my VFR... Really a fantastic product.
Agree on the Skenes. I have a set (front and rear) that have followed me around on all 3 of my bikes each time I've upgraded. Though a bit pricey, they work great. Unfortunately, I apparently damaged the rear set somehow during the last transfer to my CTX and I lost the "conspicuity flicker" feature on them. But they do still flash when I hit the brakes and that's the main reason I bought them.
Agreed. I've had people look right at me and then pull out. My defense is to ride as often as possible about 40 feet behind another vehicle. No one can pull into the empty space in front of me if there is no empty space in front of me.
View attachment 86260 View attachment 86261 View attachment 86262
Thanks for the photos...nice bike....Question ....I have a 2017 CTX DCT and was wondering if the Fehling crash bars would fit my bike?
The Fehling only fits the naked model without critical modifications. @bob witte did a write up on what needed to be modified for the fairing version.
Only if you have them modified. Both sides need to "push out" a bit which means cutting the center mount and adding 1.125" or so. I did it by gluing on a bronze bushing that fit perfectly. Since mine is a trike, the engine "protection" bars don't need any real strength (they are just for show). A two wheel installation can have that "sleeve" welded in to maintain the original strength.
Here's the link to my original posting:
:cool:
Discussion Starter · #14 ·
Thanks, Ruby. As @explorecaves and Bob Witte noted, the Fehling bars are designed for the naked CTX only. Here is an interesting alternative that may interest you. These will fit both CTX versions:
2016 Honda CTX700 DCT
Being a longtime commuter, I always add lights and 3M reflective tape, front, back and sides, to improve visibility. Of course, I still assume drivers are too distracted to notice me (or anyone else), and ride appropriately defensively at all times.
LED headlights and spots on my fork illuminate me from the front. Adding LED brake lights to my Givi topcase, plus putting 3M white reflective sheets behind the red lenses of the topcase, help in back.
86290
86291
This is from Skene website:
My lights don't flicker anymore. How can I fix it?
It is likely that the conspicuity flicker was inadvertently turned off.
This can be turned on again as follows:
Photon Blaster - front system
The conspicuity flicker can quickly and easily be switched from on to off or from off to on.
To change modes:
1) turn the ignition on, then off 3 times, leaving it on for no longer than two seconds each time.
2) turn the ignition on again, the lights will now be in the alternate mode.
The operating mode is saved, and is only changed when the above process is followed.
P3 - rear system
Program mode 7 toggles the conspicuity flicker between on and off.
To change modes:
1) With the ignition on, tap and release the brake lever 4 times (each tap must be less than 1 second long and no more than 2 seconds apart)
2 ) Make sure to wait 5 or 6 seconds after you enter the 4 brake taps for the 4 flashes of the LEDs that indicate the controller has entered programming mode.
3) Within 2 seconds after the 4 flashes, tap and release the brake 7 times (each tap less than 1 second long and no more than 2 seconds apart)
4) Wait 5 or 6 seconds after you enter your mode selection brake taps for the controller to respond with 2 flashes before you activate the brake again to try out the new setting.
5) Activate the brake and see if the mode has changed.
Not as good as lights, but i bought some 2" wide reflective tape and have put it all over my bike and on the sides of my top box. Reflects headlights very well and helps increase visibility (at night).
1 - 20 of 25 Posts
