1 - 5 of 5 Posts
I have the FOBO 2 system currently, and before I get new tires, I want the metal stems on hand.
Does anyone have info about T-valve stems, where you can put the TPMS on one side and then use the other to fill or release air? FOBO has one on their site, in Malaysia, and a coworker found this one:
I’d rather not have to ship anything overseas right now, but I’m not sure if the Raney piece is the right one. Any info would be appreciated.
I have no first hand experience with these but Wingstuff sells FOBO 2 stems. Says “Suitable for rim valve hole of 11.3 mm or 8.3mm in diameter”. Can’t confirm if they fit the CTX. The spec’s on the link explorecaves provided says “11.3mm / 0.453in fits most every Japanese manufactured tubeless tire rim since the early 80's”. I would think that is probably true.
T-Valve Optional Accessory for FOBO 2 TPMS
I’m not sure I made myself clear. I want a T valve so that I can fill the tire using one stem and keep the TPMS in place on the other stem. This is the stem from FOBO:
That’s the precise design I want (makes sense that FOBO carries it). Nothing against FOBO, I just don’t feel like international shipping is in good shape right now. So I am wondering if anyone has a similar stem that they’d recommend.
The stem I posted originally is made for trucks with dual tires, to keep both sides filled and monitored.
1 - 5 of 5 Posts
