1 - 2 of 2 Posts
Although on the NC700 the CTX is almost identical and this may help save you some money. First it shows how easy it is to change out the ratio control motor and also how simple the motor is to disassemble, clean and test before replacing it if necessary. If I had an issue and thought it was weak or bad I would definitely try cleaning the commutator bar, checking the brushes and testing the armature windings and plug socket before I would replace it.
Thank you! This video will probably help me at some point in the future!
1 - 2 of 2 Posts
