1 - 5 of 5 Posts
Hi guys..fairly new to the forum. Thanks ahead of time for the info. The question I have is I have installed Shad sh-35 bags and I want to add luggage rack. What luggage rack did you use.
Did you mount rack on top or bottom of Shad mounting bracket. Did you have to buy longer bolts to go through both mounting brackets.
The bolts that came with the shad system were too long for me without the rear rack and I had to cut them shorter. I believe you will have to mount the rear rack on top of the shad system to make them align correctly....
I have the Shad luggage rack and side Shad bags. Installed it all years ago so my recollection is stale, but I do recall getting bolts of differing lengths, partly to accommodate the rack, and partly because I sometimes remove the OEM passenger grips. [He walks into garage] Starting from the top, the sequence is passenger grip, luggage rack, side case rack.
1 - 5 of 5 Posts
