1 - 20 of 47 Posts
The bars are very close to being perfect but my wife needed just a little more pullback so I purchased the Rox Risers from Powersport Junkie, 72.95 free shipping.(WPS-44-83477B) is their part number.
Motorcycle, Dirt Bike, Street and ATV Parts, Apparel and Accessories | Powersport Junkie
roxspeedfx BLACK 2" Rise x 1 1/8" Stem Clamp x 1 1/8" Handlebar Dual Sport Pivoting Risers
Installation took me about 1hr 30min and that was taking my time, no rushing on motorcycle work. The brake hose is held in place on the lower triple tree on the front side. If you remove the bolt and release the metal bracket from the mounting clamp then there will be enough slack in the brake line. The electrical cables are attached to the triple tree on the front with a plastic push clip on each side, once removed with a flat screwdriver used as a pry tool there is enough slack. I rerouted the clutch line to behind the triple tree but that is not necessary unless you want a cleaner look. Otherwise it can be rerouted and go across the top of the ignition from right to left. I had to take the clutch lever off, unscrew the clutch line from the housing, and then reroute behind the trees. (5 min)
I highly recommend covering the plastic with a towel and be ready for the bars to come down when all the bolts are loosened.
I took the bike for a quick ride to verify no sticking cables or pulling on the electrical lines. Everything is perfect and the comfort they add is well worth $72.95. I would guess a dealer would charge 1-12 hours depending on how much they like you as a customer.
CEETEEX, looks like a well made product to solve a specific problem. Hour and a half is good time to be careful and do it right. Price is good too.
thanks for posting pics and info.
I noticed this option mentioned in another thread and figured I would bring it to the top. It has not been brought up in a while....
THANK YOU MY BRUTHA! I do risers in January, after floorboards
Can't find risers ?
Rox Riser factory is out of stock!
Powersport Junkie seems to no longer have a website!
Any other places carry them?
Pathfinder
Reactions: fjones
Discussion Starter #10 (Edited)
The description said there is a 7/8" adapter to remove. I thought the handle bars were 1 1/8" at that point. Are they 1 1/4"? Or is the stem the 1 1/4" measurement?
If the 1R-P2PPK is the correct part number then this place has them for $68.46
http://www.oemcycle.com/Item/product/900194162
Discussion Starter #13
Rox Speed FX Elite Series Pivot Handlebar Riser - 2in. - Black 1R-P2PPK
Here goes.
Clamp that holds the Rox lower is 1 1/8, that is the thickness of the stock bars until it reduces down to 7/8 at the controls.
Those are the correct ones you listed at oemcycle.
Here goes.
Ok I got it. Your post said 1 1/4" and I got confused.
Those look like a 7/8 stem clamp, you will need the 1 1/4 stem clamp.
It is a 1 1/8" stem clamp. :eek:
Since the DCT version has different controls/cables, is there any reason to believe the same "Rox Speed FX Elite Series Pivot Handlebar Riser - 2in. - Black 1R-P2PPK" set wouldn't be correct?
I'm almost certain that I'm going to need something like this due to an arthritic shoulder. :confused:
Reactions: fjones
What did these change? Height or reach? I wouldn't want my bars any higher but it would be nice to have them closer to me.
My ROX risers bring the bars back and allow me to relax my shoulders more.
Reactions: Kfrill
...I wouldn't want my bars any higher but it would be nice to have them closer to me.
That goes for me, too. I know that there are two pivot points, but if they were offered in 1" height, I might opt for them instead. I think a lot of how you configure them depends upon cable length(s).
Discussion Starter #20
Go to their website, they are offered in a number of variations. Just make sure you get 1 1/8 for the base. I am 5'7 and the rise was no issue, wife is 5'4 and works well for her. If you use the pullback it will significantly reduce the rise.
Should be same on DCT, easier because you have no clutch cable to move.
1 - 20 of 47 Posts
