1 - 2 of 2 Posts
Hi All,
After attempting to install the adjustable Rox risers that many people on the CTX forum have used, I found that I could not properly torque all four bolts of the new riser to the factory base because when I put the adjustable risers where they needed to be for proper handle bar position the risers were blocking at least two of the four holes. I called Mark at the Rox Riser Factory in MN and he suggested I go with the Rox Riser that is fixed one inch up and one inch back #3R-B12POEK. You still need to do all the cable/wiring re-locations but the final fit is perfect for me and I can torque all eight bolts to 16 ft lbs/192 Inch pounds. High confidence nothing will come apart and very comfortable/relaxed position on the arms. See attached picture.:)
1 - 2 of 2 Posts
