Dragging the rear brake ( along with staying in the friction zone) is the recommended method of slowly making tight u-turns on a motorcycle.I wouldn't recommend dragging the rear brake at all. Unnecessary wear; f
My comment was in the context if the OP, not for NOT EVER using the rear brake. OP wants to find the friction point on a DCT. Another poster said to drag the rear brake hence my comment.Dragging the rear brake ( along with staying in the friction zone) is the recommended method of slowly making tight u-turns on a motorcycle.
Don't know about the technique for scooters.
You'd have to make one **** of a turn to "unnecessarily" wear the rear brake.
Especially for those who think the rear brake isn't strong enough.
Sensitive, aren't we.....friend.I know how to use the rear brake, friend. Looks to me like you have this screaming need to jump in and be right...
Pet the cat.
f
claro que si...I don't like cats.
You will be happily surprised at how this bike downshifts automatically, so, in turns, it seems to always be in just the right gear to apply throttle thru the turn. My wife and I are two up on it all the time. Its a breeze. We can turn easily at the lowest speeds, in turns, you name it. It's low center of gravity and how it selects gears make it a lovely two-up ride.Let me rephrase my original question slightly. I've been told that when one is cornering or making a u-turn at a slow speed, keeping a bike on the friction zone will prevent the bike from falling. On the ctx700, how much throttle should I apply so I can corner or u-turn properly without risking dropping the bike? It's especially tough for me when I have my wife on board and I'm trying to make a turn at less than 12 mph. Any help would be appreciated since apparently there is no such thing as friction zone on the ctx700
Follow the example set by ex-World Champion Wayne Gardener. Practice till you fall off, then back-off a tad for the real thing. If the real thing involves someone you love, and you still want to find your limit, then you're on your own.how much throttle should I apply so I can corner or u-turn properly without risking dropping the bike? It's especially tough for me when I have my wife on board
If it's some one you love, make time.I don't have time to practice till I fall off
