1 - 9 of 9 Posts
just bought my '14 ctx700n and after a couple of rides on the freeway found out that i wished i had another set of driver footpegs further back than stock on which to rest my feet. since i couldn't find anything on the internet i made a set of my own. they work great and were cheap and easy to make and install. here's a couple of pics:
Automotive tire Bumper Automotive wheel system Machine Automotive exterior
Automotive tire Vehicle Automotive design Automotive lighting Hood
Tire Wheel Automotive tire Hood Automotive lighting
Looks good, I only installed the L. side as a step for mounting but yours looks like there’s no mod. of stock parts on the R. side..?
no mods to any stock parts at all. both sides can be removed in about 5 minutes if needed.
Looks good. Any other pics of the bracket you made?
I like your setup. I would also like to see the bracket and the model of pegs. Would you be willing to make these for people if the would pay for your effort?
the longer bracket piece is 8", the shorter one is 5.5". both are made from a piece of steel strap 1" wide by 1/4" thick, from home depot(6.00$). the pegs are Bikemaster from the bike shop($10.00)
the drilled holes are 5/16" for the pegs and the rear hole. you'll need a bolt longer than stock for the rear. the front hole is 1/4" and goes right over the small stock bolt that holds the lower plastic cover on.. very simple for the diy guy with a hacksaw and a drill. keep in mind that i'm 5'6" tall and these fit me perfectly. if you're much taller these probably will be too high up to be comfortable for any length of time unless you measure for the best placement and adjust the length of the brackets accordingly. have at it!
View attachment 89080 View attachment 89081 View attachment 89082
I just lived with the odd/unnatural position of the pegs and adjusted faster than I expected. But now I'm working on a set of retractable safe wheels for stops and starts. Can't hold 'em up like a I could yrs back and a lift kit for lifting up the bike if it falls over. Can't pick it up nowadays either. I hope to have the lift kit online by end of year.
I love this bike. this makes my 19th for life.
Thanks for the info. I might try this and see if I like it better than my setup now.
1 - 9 of 9 Posts
