1 - 11 of 11 Posts
2017 Honda CTX700D
Like many other CTX700 owners, I was not happy with the carrying capacity and the shape of the OEM Honda side cases, so I decided to replace them with a set of GIVI Trekker 46 liters. Checking on the forum I became aware of others using the JFC brackets to mount different types of side cases. I've been a Givi user with my other motorcycles and scooters so I already had some experience with the good quality of these cases, but Givi does not produce a specific set to mount side cases on a CTX700, only for the top case.
I ordered the JFC brackets as well as two Givi mounting plates. Once all these items were in my hand I proceeded to mount them on my bike. I am very satisfied with the quality and workmanship of the JFC brackets, mounting them was very easy, and no extra hardware is necessary, just removing the OEM mounts for the side cases and adding them instead. I secured the Givi plates with 4 screws each to make sure there is no vibration or the risk of losing a side case while on the road.
This first picture shows the 3 cases already mounted on the bike. All are Givi Trekker 46 liter each.
88114
Here you can see both, the JFC bracket, and the Givi mounting plate. The JFC bracket has two holes on top, those are the mounting holes to the bike. The 4 holes in the front are there to be used to mount any plate, or any side case directly to the bracket.
The Givi plate has 2 mounting areas and I was able to match the holes on the Givi plate to the ones in the JFC bracket.
88117
This is how the JFC bracket and the Givi plate should be mounted.
88119
This is how the JFC brackets look once mounted on the bike. As you can see they offer a wide mounting area for any type of side case you want to install.
88122
88121
JFC bracket with the Givi plate mounted on it.
88124
I had to secure the Givi plate with 2 extra screws to make sure there is no vibration. Also, I had to lower the Givi plate to accommodate for the side case not to be touching the handles. Before you drill any holes mount your side case temporarily and see if it looks ok, and if it is not in the way of the passenger.
88125
There is some adjustment allowed since the JFC bracket holes are big, so check what is best for your individual need.
88126
Here you can see the OEM side cases mounts still attached to the handles. I remove them and put the JFC brackets instead.
88127
And this is how the bike looks with its new Givi Trekker 46 liter set of top and side cases.
88128
Looks good.
Reactions: Hondafan
Top-notch presentation Edgar! Looks like you are ready to pack up and get outta Dodge before your home state totally collapses in on itself!! You are welcome down here in Florida to join the many New York refugees that have come here already. 😁 🤣 (y)
2017 Honda CTX700D
Looks great, though not exactly aerodynamic. How does it ride? Is there a noticeable difference in how it handles?
I took it for a ride the day I installed them and I did not notice any difference, and the day was windy. I am used to big side cases in previous scooters and bikes, and to me, it is worth the extra gas. Unfortunately, the OEM does not provide enough storage space for me.
2017 Honda CTX700D
Since these are Givi Monokey mounting plates I can accommodate any Givi side case. I have 3 sets: 21 liters, 36 liters, and 46 liters. I use the ones needed for each specific trip. Those 46 liters are for trips that involve many days and a lot of gear is needed. I also have a Sherpax trailer that I can add if more space is needed. The trailer can also carry a set of Givi side cases.
What’s the brand of your rear rack with back rest?
2016 Honda CTX700 DCT
I plan to get soft side bags one day. I'm still trying to decide whether to go with the JFC bracketz or a simpler removable metal strut just to keep the bags from rubbing the tires.
1 - 11 of 11 Posts
