1 - 8 of 8 Posts
Trying to remove my throttle grip on 2014 CTX and can’t seem to get it off. Have tried WD40 and prying with small screwdriver with no success. Don’t want to tear the grip as I’m planning on reusing it. Suggestions? Thanks
I used a fine tooth hack saw blade sliding it between the grip and tube to break the glue loose.
Try cracking the edges loose, and then roll it off.
Compressed air really helps if you have it available.
I have done it and the problem was that the original tube is jagged. My service helped by letting compressed air between tube and grip. It helped, but the rest I had to do by a thin screwdriver.
1 - 8 of 8 Posts
