1 - 2 of 2 Posts
ENGINE
Engine Type
- 670cc liquid-cooled parallel-twin
Bore And Stroke - 73mm x 80mm
Induction - PGM-FI with 36mm throttle body
Compression Ratio - 10.7:1
Valve Train - SOHC; four valves per cylinder
DRIVE TRAIN
Transmission
- Six-speed
Final Drive - Chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension
- 41mm fork, 4.2 inches travel
Rear Suspension - Pro-Link single shock, 4.3 inches travel
Front Brake - Single 320mm disc with two-piston caliper
Rear Brake - Single 240mm disc with single-piston caliper
Front Tire - 120/70-17
Rear Tire - 160/60-17
DIMENSIONS
Rake
- 27.7°
Trail - 114.0mm (4.4 inches)
Wheelbase - 60.2 inches
Seat Height - 28.3 inches
Fuel Capacity - 3.17 gallons
Mpg - TBD
OTHER
Model Id
- CTX700N
Emissions - Meets current EPA standards. California version meets current CARB standards and may differ slightly due to emissions equipment.
Available Colors - Candy Red, Black
Discussion Starter · #2 ·
Honda CTX700N DCT ABS Specifications
ENGINE
Engine Type
Ignition - Digital transistorized with electronic advance
DRIVE TRAIN
Transmission - Automatic six speed with two modes and a manual mode
Final Drive - Chain
Front Suspension - 41mm fork, 4.2 inches travel
Front Brakes - Single 320mm disc with two-piston caliper; Honda ABS
Rear Brakes - Single 240mm disc with single-piston caliper; Honda ABS
DIMENSIONS
Rake
- 27.7°
Mpg - TBD
OTHER
Model Id
- CTX700ND
Available Colors - Black
1 - 2 of 2 Posts
