ENGINE
Engine Type - 670cc liquid-cooled parallel-twin
Bore And Stroke - 73mm x 80mm
Induction - PGM-FI with 36mm throttle body
Ignition - Digital transistorized with electronic advance
Compression Ratio - 10.7:1
Valve Train - SOHC; four valves per cylinder
DRIVE TRAIN
Transmission - Six speed
Final Drive - Chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension - 41mm fork, 4.2 inches travel
Rear Suspension - Pro-Link single shock, 4.3 inches travel
Front Brake - Single 320mm disc with two-piston caliper
Rear Brake - Single 240mm disc with single-piston caliper
Front Tire - 120/70-17
Rear Tire - 160/60-17
DIMENSIONS
Rake - 27.7°
Trail - 114.0mm (4.4 inches)
Wheelbase - 60.2 inches
Seat Height - 28.3 inches
Fuel Capacity - 3.17 gallons
Miles Per Gallon - TBD
OTHER
Model Id - CTX700
Emissions - Meets current EPA standards. California version meets current CARB standards and may differ slightly due to emissions equipment.
Available Colors - Cool Candy Red, Pearl White
DRIVE TRAIN
Final Drive - Chain
DIMENSIONS
Rake - 27.7°
OTHER
Model Id - CTX700
