1 - 1 of 1 Posts
LCD Instrument Panel
Full digital LCD instrumentation includes digital speedometer, digital bar-type tachometer, clock, low-fuel gauge, and two tripmeters. The instruments are light, compact, and easy to read, too. The DCT/ABS version adds a gear position indicator.
Integrated Storage Compartment
The new CTX700 offers a convenient utility compartment that’s in the fuel-tank area, making it easy to reach.
Relaxed Rider Position
The CTX700 was designed for a comfortable, confidence-inspiring ride. The rider triangle was designed to provide a relaxed riding position for most riders, so you won't feel cramped up after just a few miles down the road.
Low Seat Height
With a seat height of just 28.3 inches, the new CTX700 is confidence-inspiring and comfortable. Combine that with the forward-set controls, and it's easy to flat-foot it at stoplights or in parking lots.
41mm Fork
With 4.2 inches of travel, the CTX700 soaks up the bumps and jolts in rough pavement, but also provides excellent handling and superior feedback through the handlebar.
Cast Aluminum 17-inch Wheels
The 17-inch wheels give you a wide choice of premium tires to choose from, and really help the CTX700 handle like a pro on the street. The cast wheels are light and strong too.
Front and Rear Disc Brakes with Available ABS
Single front- and rear disc brakes give the CTX700 great stopping power. The ABS option incorporates anti-lock brakes for the best possible stopping power, especially under challenging conditions.
Low Center of Gravity
The CTX700's low center of gravity makes for a more confidence inspiring, all-around riding experience.
Diamond-Shape Steel Frame
Light, strong, and with just the right amount of stiffness, the CTX700’s rigid and compact chassis is the foundation for precise handling.
Electronic Fuel Injection
Honda's. Electronic Fuel Injection means easy startups on cold mornings and flawless running even at high elevations.
670cc Parallel-Twin Engine
With its cylinders tipped 62 degrees forward for better weight distribution, the CTX700’s engine is a big step forward in modern powerplant design. The two-cylinder format produces tons of low- and mid-range torque, and the 270-degree-phase crank and uniaxial primary balancer make it smooth, too.
Optional Automatic Transmission
Shift with the push of a handlebar-mounted button, or select the CTX700’s automatic mode and the bike will shift itself. Honda’s Dual-Clutch Automatic Transmission (DCT) has been a huge hit on our other models, and once you ride a CTX700 with DCT, you’ll see why.
Pro-Link Rear Suspension
Offering 4.3 inches of rear-wheel travel and teamed with a Honda Multi-Action System rear shock, the CTX700 eats up rough pavement while giving you a smoother ride.
Reduced Vibration
You don't need to rattle and shake when riding a motorcycle. The CTX700's engine counterbalancer and rubber-mounted footpegs let you enjoy the ride on your commute or on a weekend getaway.
Full-Coverage Fairing
With its new full-coverage fairing and windscreen, the CTX700 really adds to your comfort on long trips. The fairing upper and lower components are unique to this model, and are integrated with rest of the bike.
1 - 1 of 1 Posts
