The CTX leans pretty good on the side stand and the filler neck has bars going across the opening. The manual shows a side view of the neck but I think I am using a lower fill point but at least I can be consistent between fill ups. That said I used 2.198 gallons to go 146.6 miles. I estimate that to be 66.70 miles per gallon. If you do the math, there should have been about a gallon left in the tank or enough gas to go roughly another 50 miles easily.
Breaking it in, I tend to not hold the speed too steady. It is better to work the engine up and down the rpm range and not over rev or lug it. The break in period is 300 miles
