Here you go - a virgin (never taken off) photo before my oil change yesterday. Dbl-click to make it a little larger.DCT filter change way easier than expected. Spent most of the time figuring out which end of the cap goes up as it seems it can go either way! (bevel side up).
Did my first oil change today. Everything went well except getting the oil filter off. It took 4 wrenches before it would loosen. I used Lucas 10w 30 and honda filters (dct filter changed too). This was my first ever oil change for anything except a lawn mower. It's purring!!
I've seen some workshop guys and they just grap a big heavy screwdriver and drive it into the old filter with a mallet. Then they have the leverage to get it off quickly...time is money. They also have a bigger than average container underneath for everything to fall into. New one goes on with just the smallest smear of oil on the o-ring and do the new filter up real tight with just clean strong hands, or the smallest "nip" with a short spanner if the filter has a hex end. New filter is straight out of the box and squeaky clean as well.Everything went well except getting the oil filter off. It took 4 wrenches before it would loosen.
I had trouble as well. Honda Japan got a little overzealous in the torque they apply to these oil filters. I only used two wrenches. I bought a plastic socket-type filter wrench that one attaches to a ratchet. I stripped the wrench on the ratchet side on quick order. I took it back and the clerk stated that it was guaranteed not to strip, so he gave me a refund. I then exchanged for one of those channel-lock style wrenches that is more expensive. It took a lot of griping pressure and turning pressure to get it loose. But it won't happen next time. I tightened just beyond hand tight like filters are supposed to be tightened.Did my first oil change today. Everything went well except getting the oil filter off. It took 4 wrenches before it would loosen. I used Lucas 10w 30 and honda filters (dct filter changed too). This was my first ever oil change for anything except a lawn mower. It's purring!!
I run T6 in it but have manual transmission. Now have 2995 miles on CTX. Since you have other bikes, you are not new to oil changes. Use the oil you want not necessarily the oil anyone else says they use and why. It's your bike.Anyone running Rotella T6 in this bike, I run it my other bikes and like it but don't know how it would fair in the DCT?
