1 - 10 of 10 Posts
Good day,
I was wondering if you can or is there an ability to install a fairing kit on a CTX700n? I been searching around the net, but haven't got a positive answer of yes or no?
Thanks
Orion
Good day,
Thanks
Orion
Sadly, your answer is "no" -- there is no fairing add-on for the naked versions except for some jerry-rig DIY item. Search around the forums here and you can see a few examples. You can come close with a couple of the aftermarket windshields however.
Think outside of the box on this one.:)
No aftermarket kit available and installing OEM fairing is financially out of the question (about $2600.00). Should have bought a faired version since its only $600.00 more than the N model.
+1 for aftermarket windshields, but finding factory mounts that work might be a bit of a trick. You may end up having to be creative.
Good day,
Thanks
Orion
No kit specific, but there are universals available. Most are small and have attachments to the handle bars.
I did more modification than most. I wanted a larger fairing so I did some considerable carving on a universal brand windscreen, repositioned the turn signals and attached to the handle bar crown as well as to the upper forks.
Gordon,
Thanks for the idea's. I will go look at some aftermarket windscreens and see what I can come up with.
Thanks again
Good day,
Thanks
Orion
I have the same model 2014, looking for the same thing.
This reply, above, sums it up accurately.
Reactions: explorecaves
Attached is a member who retrofitted a National Cycle Plexifairing To his naked CTX. If they would have made one to properly fit the bike every naked CTX would be wearing one.
Plexifairing on CTX700N
1 - 10 of 10 Posts
