1 - 10 of 10 Posts
I just figured out that when traveling on the freeway 65-70 mph, all you have to do is quickly give it gas (gun it) and the DCT will downshift from 6th gear to 5th gear and take off.
I ride pretty conservatively and don't usually gun the throttle. When I pass 18 wheelers on the freeway I gradually give it gas and the bike stays in 6th gear. I knew I could manually downshift but too lazy or didn't need or want to concentrate on hitting the downshift button. Now there is no need to hit the downshift button to pass. :)
And when I was getting on the on-ramp at 40 mph, I gunned it and the bike downshifted from 6th gear to 4th gear and took off. :)
Oh yeah, I'm 100% in the Drive mode.
Yeah, you are right,,,,, it does downshift as needed, automatically.
If you need very agressive throttle response, within the limits that the ECU will allow the engine to perform under, auto is no bueno.
So I shift into manual to get the exact throttle response needed, if you're doing things in a leisurely or semi-leisurely fashion than either auto works.
My experiences with the CTX700 basically make me want to get a faster bike, doubtful i'd ditch this if I got it but I still want a real sport-touring bike.
The DCT basically operates like an automatic transmission in a car or truck.:)
Give the downshift button a push - just a single thumb press... :) The DCT won't let you downshift too far (can't shift into 2nd at 70 MPH) nor will it let you upshift too far (6th at 20 MPH).
Discussion Starter #8
It makes sense that the DCT functions like a automobile transmission. It's just that on the freeway, I cruise with a Crampbuster on the throttle. With the Crampbuster, I don't tend to make very big changes in the throttle movement, so the bike doesn't downshift from 6th to 5th.
My buddy with a NC700, that turned my on to the CTX700 DCT did not realize automatic downshifting either. He would manually downshift to pass on the freeways.
I guess some of us old geezers are too easy on the throttle. :)
Often times the twist the throttle downshifting is too aggressive for the situation so the paddle buttons of manual mode works better. I think someone already said that...
Yes, a slight tap of brakes does induce a DCT downshift.. for Each gear, if you care to do such on stoplight approaches... kool!
1 - 10 of 10 Posts
