1 - 2 of 2 Posts
CTX700
ENGINE
Engine Type: 670cc liquid-cooled parallel-twin
Bore And Stroke: 73mm x 80mm
Induction: PGM-FI with 36mm throttle body
Ignition: Digital transistorized with electronic advance
Compression Ratio: 10.7:1
Valve Train: SOHC; four valves per cylinder
DRIVE TRAIN
Transmission: Six speed
Final Drive: Chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension: 41mm fork, 4.2 inches travel
Rear Suspension: Pro-Link single shock, 4.3 inches travel
Front Brake: Single 320mm disc with two-piston caliper
Rear Brake: Single 240mm disc with single-piston caliper
Front Tire: 120/70-17
Rear Tire: 160/60-17
DIMENSIONS
Rake: 27.7°
Trail: 114.0mm (4.4 inches)
Wheelbase: 60.2 inches
Seat Height : 28.3 inches
Fuel Capacity: 3.17 gallons
Miles Per Gallon: 64 MPG*
OTHER
Model Id: CTX700
Emissions: Meets current EPA standards. California version meets current CARB standards and may differ slightly due to emissions equipment.
Available Colors: Cool Candy Red, Pearl White
FACTORY WARRANTY INFORMATION
One Year: Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Note: *Honda's fuel economy estimates are based on EPA exhaust emission measurement test procedures and are intended for comparison purposes only. Your actual mileage will vary depending on how you ride, how you maintain your vehicle, weather, road conditions, tire pressure, installation of accessories, cargo, rider and passenger weight, and other factors.
Discussion Starter · #2 ·
CTX700 DCT ABS
ENGINE
Bore And Stroke 73mm x 80mm
DRIVE TRAIN
Transmission: Automatic six speed with two modes and a manual mode
Final Drive: Chain
Front Brake: Single 320mm disc with two-piston caliper; Honda ABS
Rear Brake: Single 240mm disc with single-piston caliper; Honda ABS
DIMENSIONS
Rake: 27.7°
Seat Height: 28.3 inches
Miles Per Gallon: 61 MPG*
OTHER
Model Id: CTX700D
1 - 2 of 2 Posts
