If you have ever done any long rides you probably found your right hand needing a rest. In the past most of the bikes I rode had a built in electronic cruise control.
The CTX doesn't. I happened to notice a device that seems to have some merit. It is called GoCruise and you can see it on www.2wheelride.com.
The web site only shows the composite unit but there is a newer version made of aluminum, either black or polished aluminum.
The new version has an adjustable tension device, where as the composite unit only has one setting.
I bought the aluminum unit which sells for about $36.
