1 - 5 of 5 Posts
There is a plug at the front of the motor on the right side if I remember right side looking at the bike from the rear. Probably have to remove the bottom front plastics (the black ones ). Not sure if you can refill it without taking more plastics off. I did mine when I had everything off to check the valves.
With my "D" fairing model, I refilled the radiator with a long necked funnel & without removing extra plastic (tupperware). Also: read manual about "bleeding" air from cooling system before assuming it is full of new coolant.
1 - 5 of 5 Posts
