Do those of you with the auto transmission put the transmission in neutral as you come to a stop?
I was trying to think of when you would ever do it and that is a good one.Same here. I only put it in N when I put the kickstand down to open a gate or before I turn the engine off.
I don't think you can put it in gear unless it is running.Anybody figured out if you can push start the DCT if you had to? (Like weak battery or bad starter/solenoid)
LOL! I really should take the seat off and find my owner's manual.I don't shift into neutral with my manual transmission bikes and simply hold in the clutch so I am ready to go. Automatic should not be put into neutral if stopped for a light. Just let the bike idle. I will not die if idle is set correctly according to the owners manual.
