If you have mounted the webike stand......
Yeah I know, the manual and the shop manual say you're supposed to stand the bike up straight, not let it lean when checking the oil. So I did a little test. I did exactly what you're supposed to do to check the oil;, let it run for five minutes , shut it off , check after three minutes, and the levels were exactly the same whether it was on the center stand or stood up straight from side stand (straddling).... Exactly the same. So it must ask you to hold the bike up straight not because there's an angle from front to back, but just side to side… so much **** easier to check it on the center stand…
