Several experienced riders have posted on here they they've got 3,000 or more miles on their CTXs with chain tension still within specs and no adjustments so far. I assume this is a good indicator that proper care is being taken with respect to their chains and sprockets and that long chain and sprocket life can be expected due to this lack of adjustment necessity.
Is my assumption correct?
What does it mean if I've got 3300 miles and have adjusted twice; both times in the last 800 miles? There is, however, still alot of adjusting /stretching left before it goes into the red area. I've ridden alot in the rain and expect to continue to do so, since I'm a daily commuter. Is very short chain and/or sprocket life inevitable if I've chosen to ride in rainy and wet/grimy road conditions, or does anyone have any tips to help someone get the most out of his chain drive system if he is regularly getting the chain wet?
I know that I've become somewhat obsessed with this one service aspect and have hit on it alot lately in different threads, but it's just something that I'm trying to find the smartest, easiest, and best way to approach going forward. Originally, I was mostly going by the manufacturers' mileage recommendation of 500 miles and not really paying much attention to what was going on beyond just attending to it every 500 miles and I think this might be why I've experienced the premature need to adjust the slack. I don't think that's going to be the best way to approach chain service in the future thanks to what I've learned on this forum; the fact that it is the actual condition of the chain caused by environmental factors; not mileage or time intervals that is the biggest factor regarding cleaning, lubing, and slack adjusting necessity.
I've expressed my ideas on other threads about always wiping the chain off with a dry rag after every ride if the roads are wet, grimy, or salt-power covered and then more thoroughly cleaning and re lubing at my first opportunity but haven't received any feedback about this idea. The hardest thing about executing this plan is that sometimes it will be inconvenient to do this immediately after parking, and it will be hard to do at work where I have no rear stand. I could make this more convenient with a second rear stand to keep at work or mounting a center stand, or I could just make some marks in the work parking lot at set distances and then stop, wipe off, roll forward, wipe off, roll forward and the wipe off. Not very simple long term but maybe until I can afford another rear stand to keep at work. Is my idea worth it? or does anyone have a better ideas to most simply take better care of my chain and sprocket?
I've removed that small plastic piece that partially covers the lower chain area to make wiping down the chain easier and to get more of it while the bike is in one spot. This should help some.
