The CTX700 requires the NC700S center stand. Not the NC700X which is too tall. The correct part number is 08M70-MGS-J10. If you ordered the center stand with the part number ending with 30, you ordered the wrong one.
The NC700S model is not sold in the US so you have to order the stand from Japan!
The correct stop part number is 35-21-01. This is an aftermarket stop designed for the NC700X.
__________________________________________
After using the Trackside stand which worked well I decided I wanted a center stand. I was afraid the NC700X stand would be too tall and I did not want to cut and weld but after researching the NC700 forum I found the NC700S stand (1.6" shorter). I ordered the stand for $90.72 plus shipping, the total was $117.21 from here (Motorcycle Parts & Accessories from Japan - Webike)
Highly recommend buying the center stand stop at the same time,
OVER : Center stand stopper [35-21-01]
Delivery was 4 days from Japan and I got a email with tracking info. Install can be done with an average mechanical ability. The springs are tight so getting the shaft to slide into the slot took patience and leverage. I put the springs on and pulled the stand until I could get my wife to tap it in place. The stand will bolt directly in place and the spring pin hole is already threaded. Everything is a direct fit. Also the two exhaust clamp bolts will need to be rotated enough for the springs to clear. Best to get the stop bracket with the stand. See later posts.
The bike is very easy to get on the stand and it is a great addition.
