I've got a rear paddock stand from Cycle Gear. It's on sale this month online for $49; regular $109. Cycle Gear runs this sale often. It doesn't look like free shipping is available on this item, but if you live near a Cycle Gear store, and they've got them for sale in the stores (they usually do), you can get it for that price.
I highly recommend this stand for those who want to go on the cheap without sacrificing quality. It's a one-piece, very strong stand. Probably not as strong as the Pit bull stand but as strong as it needs to be for long, durable, trouble-free, easy-to-use service. It has a long handle and lifting is quite easy, even without help.
I've also got the front stand. It's good too but the handle is not as long, and it requires more grunt to lift the front than it does for the rear. However, I don't use the front stand often, because I can pretty much clean the front wheel, the underneath area in the front, and check the front brake without lifting the front, but I have used it a few times and both stands work well together although the bike can freely roll when up on both stands, so one has to be careful about slopes, wrenching, etc. when it's all the way up off the bike wheels. It has to be chocked if working on it while on the stand wheels.
The only negatives I find with the rear paddock stand are:
(1)The end plastic pieces on the handle won't stay on. If you want to keep them without constantly picking them up out of the driveway, you'll have to glue or tape them on. These end pieces are only cosmetic though and have no function other than to keeping the stand from scratching someone or some thing if it accidentally comes in contact with the stand ends.
(2)If you use it without spools, one has to figure out the sweet spot to place the lifting pads. If you're adjusting chain slack, you have to make sure you get the pads forward of swing arm adjustment area; but, on the other hand, if you put the pads as far forward as possible when you lift it, when you put the bike down off the stand, it'll bend the sh** out of your license plate. This is one thing that would make spools come in handy. Easier and quicker and less fore thought to lift the rear wheel with spools. No chance of one of the pads not being flat when raising. I've never had a problem, but if you're not looking when you raise it, and one of the pads is cocked at a 45 angle, instead of a 0 angle, it could cause the bike to tip; whereas spools would make this simple. Just one quick look to make sure the stand has hooked the spools, and you're ready to lift.
Due to the CTX's low CG, it's very easy to use it with a rear stand. I just make sure the front wheel is straight and that I've got the bike in a fairly-level, unbroken paved or concreted area; place a piece small piece of 2X6 under the side stand and make sure its still got a slight lean to the left. Since the bike has such a low CG, it does not want to tip over very easily, so one can get it almost straight up and down and still be safe. I'll put the side stand on the 2X6 and then just keep my hand on the bike to make sure it's not going anywhere while I walk around to the rear. Once at the rear of the bike, I'll put the stand in place letting the pads sit in the spot where I want them to lift the bike. I'll then grab the right grab handle from the rear, tilt the bike until both pads are in contact with the swing arm; grab the lifting handle and pull down all the way. Very, very easy once it's done once or twice.
If you choose the rear paddock stand, make sure you pick the one that is Cycle Gear's Trackside Rear Paddock stand; not the one listed as simply Trackside Rear stand. What you want is the stand that is regular $109; not the one that has a regular price of $79. The cheaper one is multi piece and is a piece of crap with a short handle with not enough leverage or strength to make it a good stand for this bike.
Get this one:
TRACKSIDE - Rear Paddock Stand - Rear Stands - Stands - Accessories - CycleGear - Cycle Gear
Not this one:
TRACKSIDE - Rear Stand - Rear Stands - Stands - Accessories - CycleGear - Cycle Gear
One question I've got from others who may know. It's mentioned that spools + a stand is cheaper than a center stand but what's been posted on here for spools, if I remember correctly, is like $160 just for the spools and kit to mount them. Is there a cheaper spool alternative? I want spools, but I don't want them that much.
