700n top end engine noise - Page 2 - Honda CTX700 Forum
 3Likes
post #11 of 13 (permalink) Old 06-29-2018, 11:36 PM
Have to say this noise as described is not normal at all. There has been no unusual noise from my CTX engine at any speed since new. In fact at highway speeds, you can barely hear it running.
2014 CTX700D manual: Corbin saddle, Cee Baileys screen, Honda saddle cases
ScooterTrash21 is offline
post #12 of 13 (permalink) Old 06-30-2018, 12:05 AM
Noise to one may be music to another. At any moment in time, we may become more sensitive to a noise or just notice it more. Or, it could be a real problem requiring a trained technician to diagnose the problem without having to tear down the bike and replace everything .
Its always hard to say when a noise heard may be a problem or not without actually hearing the noise and tracking it down. At the minimum, a good description of the noise is needed. There's at least a half a dozen mechanical things that can generate noise right off the top. Keep in mind, forum diagnosing a problem is just that. Its either an educated guess or a wild shot in the dark.
post #13 of 13 (permalink) Old 06-30-2018, 12:28 AM
Flabbycakes's Avatar
My CTX with the manual transmission has made a strange persistent squeaky noise in 6th at 55-60mph for the last 5,600 miles (since new). Hasn't got worse or better, but the bike runs and rides great, so I always assumed it was just a quirk.
Flabbycakes is offline
post #14 of 13 (permalink) Old 06-30-2018, 01:10 AM
Squeaks are always the hardest to find, especially when they only occur at specific speeds. Could be virtually anything. The only way to find it would be to track it down by its general location and then start concentrating on the specific location. I've had people bring me their bikes swearing their engines are falling apart only to find a windshield bolt is loose causing it to squeak and I even discovered a dry ignition switch/key was causing a squeak at speeds over 50 mph. A little lube and all was fixed.
