Gear Position Indicator - Honda CTX700 Forum
 17Likes
post #1 of 28 (permalink) Old 03-18-2019, 09:48 PM Thread Starter
I have a 2014 CTX 700N naked bike.
I stumbled across a company that sells a gear position indicator that mounts on the handle bar. But wasn't excited about it.
Then I found a company that you send them your speedo cluster and they miraculously install a gear position indicator inside the cluster right of the high beam indicator.
I wonder if anyone has taken their speed cluster apart and also if having my speed cluster changed if there is anything else needs to be done to have the gear position show up on the cluster.
Does anyone have any input with having done anything like this.
Thanks
Rdub
Rdub is offline
post #2 of 28 (permalink) Old 03-18-2019, 10:07 PM
The gear position indicator is already there on both of my DCT's... I assume you do not have a DCT?
post #3 of 28 (permalink) Old 03-18-2019, 10:11 PM Thread Starter
Correct, mine is NOT a DCT
Rdub is offline
post #4 of 28 (permalink) Old 03-18-2019, 10:12 PM
The_Bachelor's Avatar
Does anyone else see the irony that only the automatic transmission has the gear indicator?????......
Adam_AU, Keco, rossmcgrath and 6 others like this.
Brad Bachelor
"Marrying an old bachelor is like buying second-hand furniture." - Helen Rowland
Current: 2018 CBR300
Former Rides: 1971 Honda CT90, 1973 Honda CB175, 1978 Yamaha XS650, 1981 Honda CM200T, 1983 Yamaha XJ650 Turbo,1983 Honda VF750S, 1985 Kawasaki GPZ550, 1989 CBR600F1, 2006 Yamaha TW200, 2006 Suzuki GZ250, 2014 Honda CTX700N
The_Bachelor is offline
post #5 of 28 (permalink) Old 03-18-2019, 10:26 PM
I've never heard of anyone doing this to their cluster. At least not on the forum. There are plenty of threads on accessory gear indicators. Everything from $30 Chinese knockoffs to $100+ over priced ones. Just makesureit plugs into the DLC connector.
post #6 of 28 (permalink) Old 03-20-2019, 10:19 PM
Honda figures the guy who manually shifts will know what gear he's in,
the automatic DCT guys would have no idea!
jfc77320, CTX2fer and david1954 like this.
rossmcgrath is offline
post #7 of 28 (permalink) Old 03-20-2019, 10:38 PM
Iím so paranoid at stoplights, people must think Iím keeping time to music with my foot.... what Iím really doing is checking and re-checking if Iím in first gear or not......
david1954 likes this.
Brad Bachelor
post #8 of 28 (permalink) Old 03-20-2019, 11:03 PM
I've done that. a lot. I've also started in 2nd gear. No big deal.
i really do like this bike!
post #9 of 28 (permalink) Old 03-20-2019, 11:10 PM
The DCT gets the indicator due to the ability to manually shift back and forth, in and out of automatic mode. The indicator tells a lot more than just what gear your in. It tells us what mode we're in, whether in neutral or not, and whether there is an error with the system.
The_Bachelor likes this.
post #10 of 28 (permalink) Old 03-20-2019, 11:26 PM
david1954's Avatar
Now for a question being I don't have a DCT. If you have it in the manual mode and lets say you are in 3rd and come to a stop without downshifting will it remain in 3rd or not? Never have ridden one.
David
david1954 is offline
