replacing front fender - Honda CTX700 Forum
 10Likes
post #1 of 15 (permalink) Old 08-29-2019, 10:34 AM Thread Starter
I had a little accident this morning and now want to replace my front fender which got cracked. The job sure looks easy, three bolts on each side, then I looked at the exploded diagram that comes with the part ordering system and there a help of a lot more parts then you would expect. Has anyone taken off their front fender and is there anything I should know about it? Is it hard to get the fender brace lined up with the holes on the fender?
VTCTX700 is offline
post #2 of 15 (permalink) Old 08-29-2019, 11:15 AM
As I remember, remove the six bolts you've identified, lift it up a bit and tilt to one side, then pull it forward to remove. The misc stuff (the brace, reflectors, brakeline guide, etc.) you see in that drawing all connect in one way or another to those six bolts. Not hard.
Ruby and explorecaves like this.
post #3 of 15 (permalink) Old 08-29-2019, 11:58 AM
Yep, lift the front wheel off ground, detach brakes, remove wheel and the rest of the fender brackets and brake line holders. Fender slides up and down, not forward and back.
Not easy to do if you have no proper tools or equipment!
post #4 of 15 (permalink) Old 08-29-2019, 12:19 PM Thread Starter
You have to remove the wheel to replace the fender?
VTCTX700 is offline
post #5 of 15 (permalink) Old 08-29-2019, 12:50 PM
Absolutely, the fender shapes around the forks. Common practice on most plastic fendered bikes.
post #6 of 15 (permalink) Old 08-29-2019, 01:21 PM Thread Starter
And you have done this before? Removed the front fender on a CTX700 and you had to remove the wheel?
VTCTX700 is offline
post #7 of 15 (permalink) Old 08-29-2019, 01:22 PM
Negative. I did not pull my wheel when I painted my bike. Once you have everything disconnected, you can slide the fender up and tilt a touch to clear the forks. Then you just rotate it out.
BobWitte likes this.
post #8 of 15 (permalink) Old 08-29-2019, 01:36 PM
Yep, that's how I remember doing it, although it has been a couple of years since. I can't promise that CRS may have taken that part of my brain over in the meantime.
explorecaves likes this.
post #9 of 15 (permalink) Old 08-29-2019, 07:46 PM
If it works for you great. With the fork brace, everything in the way and keeping an eye on the paint/body, the risk is yours.
Yes, I have done it before.... https://www.ctx700forum.com/forum/wh...tml#post420042
post #10 of 15 (permalink) Old 08-29-2019, 11:08 PM
Not rocket science nor brain surgery, Reb. Besides, they've got a bunged up fender to practice on while they find a new one to replace it. By the time it is removed/replaced a couple of times their steady hand could do it blindfolded with the speed & precision of a pit crew chief.
Taking off the front wheel is a huge pain (and I've done that more than once as well). Being lazy enough, I'd do mine with a twist in a heartbeat.
