how to adjust park brake? - Honda CTX700 Forum
 6Likes
post #1 of 11 (permalink) Old 06-25-2017, 08:51 PM Thread Starter
vysmaster's Avatar
The manual helpfully tells you to take it to the dealer... How hard could it be to adjust the park brake? Has anyone done it?
JH700CTX likes this.
vysmaster is offline
post #2 of 11 (permalink) Old 06-25-2017, 09:47 PM
Super easy but you need the service manual. Minor adjustments can be done at the top lever cable adjuster and major adjustments done at the caliper.
post #3 of 11 (permalink) Old 06-26-2017, 07:41 PM
You can adjust the parking brake at the left hand side pull the sleeve down the cable and you will see the adjusting nut loosen the nut and twist the shaft, you will feel resistance when it is getting tighter. Try the brake you will feel it has resistance or that it needs more adjusting. Try not to make it to tight you don't want to stretch out the cable, the cable will have to be changed at some point when there is no more adjustment left so don't over do it.
vysmaster and JH700CTX like this.
Bill steele is offline
post #4 of 11 (permalink) Old 09-09-2019, 11:58 AM
richr's Avatar
Followed your instructions. Park brake now holds. Thanks very much
richr is offline
post #5 of 11 (permalink) Old 09-10-2019, 03:16 PM
I'm going to adjust my parking brake as well. How tight should it be? The same as front and rear brakes or just a little less? I don't want to snap the wire
jrider is offline
post #6 of 11 (permalink) Old 09-11-2019, 08:47 AM
If you noticed on your break lever there's two little triangles. You need to get the rear wheel off the ground and spin the wheel. The parking brake should stop the wheel between those two markings.
Daddy Dave likes this.
Super Sneaky Steve is offline
post #7 of 11 (permalink) Old 09-12-2019, 08:45 AM
I test the adjustment in real life, i.e., does the brake hold the bike on the steepest hill I would park on?
Vroomr is offline
post #8 of 11 (permalink) Old 09-12-2019, 08:55 AM
It may not pass that test, especially if your valley streets are pretty steep. Do like I do with my trike (that I installed the park brake on, even though mine is a 6-speed manual). I carry a double-sided velcro strip to lash the front brake to engage it. This makes sure the trike is secure, with no excessive strain on the transmission.
explorecaves likes this.
post #9 of 11 (permalink) Old 09-15-2019, 10:30 PM
Great idea!
BobWitte likes this.
jrider is offline
post #10 of 11 (permalink) Old 09-16-2019, 07:09 AM
Park front end down and face the wheel into the curb if there is one....
This a test signiture
Danny W. Burdick is offline
