MC oil info - Honda CTX700 Forum
 3Likes
  • 2 Post By olegoat345
  • 1 Post By Evangelos k
post #1 of 7 (permalink) Old 12-18-2019, 01:15 PM Thread Starter
MC oil info
Some motorcycle oil info from "Motorcycle Consumer News" mag. June 2019; tech writer; Kevin O'Shaughnessy
It's too long for me to type it all, it's techie, gets into chemical properties & how they work......I'll just give the hi lights.
Subject: Japanese Automotive Standards (JASO) MA / motorcycle oil.
These are safe for; wet clutch (friction/grip requirements); flat tappet cams (wiping load) ; integrated transmission (gear load)
NOTE :: the letter codes; "T4"; "T6" & "4T" make it MC oil on brands listed below.
JASO MA rated (safe for motorcycles w/ wet clutch) Same "brand name" with different letter codes are NOT JASO MA rated.
Shell Rotella "T4" (heavy duty diesel) 15w-40; MA-yes; MA2-yes
Shell Rotella "T6" full synthetic (diesel) 5w-40; MA-yes; MA2-yes
Mobil 1 4T (motorcycle) all viscosities MA-yes; MA2-yes (note; V-twin non-wet clutch MA - NO; MA2 - NO)
Other JASO MA / motorcycle oils mentioned rated JASO MA "okay," Yamalube; BMW; AMSOIL; etc. oils with JASO MA rating on label.
For me personally, I've been using AMSOIL products since 1988, in "everything" I own. I've never had a oil related issue.
Motorcycle Consumer News has been around for 50 years. They do not have any ads ( zero, zip, none) making it a bit more costly. BUT they are not beholding to anybody and print their test findings, good, bad, or indifferent.
Ponydrvr and kujawskir like this.
olegoat345 is offline
post #2 of 7 (permalink) Old 12-19-2019, 06:56 PM
I always bought brand name synthetic, any known brand, that was on sale. I thought I would never say this about oil, since they are all similar, but I will say it. Since I tried Motul 7100 on 3 BIKES within maybe 3 week’s span, and ALL 3 saw an actual drop in the temp gauge and fantastic shifting, again, all verified within 3 weeks on 3 different bikes, I’m not going to anyone else.
kujawskir likes this.
-2013 Triumph Street Triple R
-2017 Honda CBR1000RR
-2018 Triumph Tiger XRx
-2019 Kawasaki Z900RS Cafe
Evangelos k is offline
post #3 of 7 (permalink) Old 12-20-2019, 02:57 PM Thread Starter
MC oils need "certain additives" to be JASO MA rated, so they can protect your clutches & other noted parts.....Check the label for specs. just to make sure you're okay.
post #4 of 7 (permalink) Old 12-20-2019, 04:47 PM
Ponydrvr's Avatar
Does the Motul 8100 carry a JASO MA rating? MA2? I didn't see it referenced in the limited specs I could find.
Ponydrvr is offline
post #5 of 7 (permalink) Old 12-21-2019, 08:42 AM
Unless I am missing something, It appears Motul 8100 is an automobile oil. I would not use it in any motorcycle.
vb18 is offline
post #6 of 7 (permalink) Old 12-21-2019, 12:17 PM
You are correct, and it should have been 7100 (!)
post #7 of 7 (permalink) Old 12-21-2019, 12:18 PM
I screwed up, it is Motul 7100. And it absolutely does carry and exceed all specs.
