Rev limiter - Honda CTX700 Forum
 41Likes
post #1 of 43 (permalink) Old 01-13-2016, 12:22 AM Thread Starter
Reed47's Avatar
Lightbulb Rev limiter
Hey guys anyone know of any mods for moving rev limiter or possible computer upgrades? I'm not sure what controls everything on this bike but I'm sure someone out there has tinkered with this bike.
Thanks for the input.
~Reed~
2014 Honda ctx700n
Corbin seat
Honda back rest and luggage rack
Honda hard bags
Madstad windshield
Reed47 is offline
post #2 of 43 (permalink) Old 01-13-2016, 12:37 AM
JH700CTX's Avatar
There are mods floating around for dyno usage but i've seen no posts here indicating anyone's tried to remove the rev limiter or bypass it.
CTX700 DCT ABS, (Sold it) Bye Felicia!
BMW 2015 K1600 GT:
  • 160hp, 130FT of torque.. The ultimate F-U to endless pavement.
  • Mileage - 48MPG
  • (working on mods for it)
Content contributor to SolidState Citizen on Blogger
Bike contemplation List:
2019 KTM-1290 SA-R, 2019 BMW R850GSA, 2019 KTM 1090
JH700CTX is offline
post #3 of 43 (permalink) Old 01-13-2016, 01:29 AM Thread Starter
Reed47's Avatar
Does anyone have Insite on how many more rpms this engine can turn with current setup? I know for a bike it sure seems like the red line is super low....
2014 Honda ctx700n
Corbin seat
Honda hard bags
Madstad windshield
Reed47 is offline
post #4 of 43 (permalink) Old 01-13-2016, 02:02 AM
JH700CTX's Avatar
The rev limiter is around 6200-6500 rpm's, i've hit it on many occasions.
I've yet to peg it in 6th gear because you'd have to be doing 125 or something. (Keep in mind 105-110 is around 5600 in 6th)
If you are looking to go faster this is the wrong bike for you, my eye wanders towards other bikes such as the VFR, you could score a used VFR for a very good price.
BMW 2015 K1600 GT:
  • Mileage - 48MPG
JH700CTX is offline
post #5 of 43 (permalink) Old 01-13-2016, 07:21 AM
The only way is to change the PCM's programing. I don't see why you would want to anyway, it is already tweaked for efficiency and durability. Going anymore can and will result in serious engine damage, that is why it is there in the first place. The rev limit is just fine for this engine. All engines are designed and run differently. If it was a 180 crank for instance, the rev limit would be around 12k, but power output would drasticly change throught the rpm-powerband. The CTX and its engine are not sport or race bike in anyway. If your hitting the limiter, you need to shift sooner! Still not fast enuff for you, you need a faster bike!
fjones, armycw2 and El Gato like this.
post #6 of 43 (permalink) Old 01-13-2016, 10:58 AM Thread Starter
Reed47's Avatar
I know peak hp is at the top of the rev limiter. If your just getting out on the highway and getting up to speed you can hit the limiter very quick. I'm sure the current programming is set up for low end and for emissions.
fjones likes this.
2014 Honda ctx700n
Corbin seat
Honda hard bags
Madstad windshield
Reed47 is offline
post #7 of 43 (permalink) Old 01-13-2016, 11:56 AM
The rev limiter is set at 6500 rpm. The CTX is also speed limited to 106 (+/- 2) mph. Max HP: 47 @ 6250 rpm. Max Torque: 44 ft-lb @ 4750 rpm.
As far as its potential, 670cc parallel twin is more than capable of producing more hp but then one has to ask at what cost and benefit. The 670 is a long stroke motor with a 270 degree crank specifically designed for low to mid range torque. Its efficiency is already at the top of its ball game by a considerable margin. The flat torque curve guaranties 40 ft-lbs of torque through out its power band. No small feat for a small cc engine.
As far as changing the PGMs mapping, there is currently nothing on the market which will allow this that I'm aware of and Honda has no intent on changing it. It is what it is. You might want to consider shifting a bit earlier than red line since ultimately you face issues of diminishing returns that can actually slow you down.
armycw2 and kujawskir like this.
post #8 of 43 (permalink) Old 01-13-2016, 02:20 PM
armycw2's Avatar
Horses for courses... This is trotter, not a thoroughbred.
This place is living proof that you REALLY DO meet the nicest people on a HONDA!
2015 CTX700 DCT ABS Gray Blue Metallic
Honda OEM Saddlebags
Cee Bailey Saddlebag Liners
Corbin Low Profile Seat
Honda Center Stand
GIVI Windscreen
Honda Rear Carrier
Left Hand Brake Conversion
Integra Left Hand Adjustable Brake Lever
GIVI E450NA / ADMORE Light Kit
armycw2 is offline
post #9 of 43 (permalink) Old 01-13-2016, 02:31 PM
I'd beg to differ -- they are thoroughbreds that trot very nicely!
kujawskir likes this.
post #10 of 43 (permalink) Old 01-13-2016, 02:45 PM
armycw2's Avatar
Yes but no trotters that run a 1:40 mile! Its more fun to ride a slow bike fast than a fast bike slowly
Honda Center Stand
GIVI Windscreen
Honda Rear Carrier
armycw2 is offline
