Discolored Sprocket - Honda CTX700 Forum
 24Likes
post #1 of 19 (permalink) Old 09-21-2019, 08:19 AM Thread Starter
mzflorida's Avatar
Discolored Sprocket
Hi everyone. I accidentally sprayed the sprocket with some wheel cleaner which caused it to discolor. Any suggestions on how to restore it back to original or do you know if it is possible? Thank you all in advance! Apologies if this is not the right area to post this in.
mzflorida is offline
post #2 of 19 (permalink) Old 09-21-2019, 08:38 AM
Spray the rest to even it all out. It won't hurt the sprocket none, all you did was stain the galvanization.
BobWitte and Ruby like this.
post #3 of 19 (permalink) Old 09-21-2019, 08:51 AM Thread Starter
mzflorida's Avatar
That is a very good suggestion. Thank you! But, I am that guy...bothers me knowing it is there. Any ideas on how to restore it short of replacing it? Thank you again for the suggestion.
post #4 of 19 (permalink) Old 09-21-2019, 09:37 AM
replacing just the rear sprocket would be a "no no" (and a lot of work) as you're suppose to replace front, rear & chain as a set so they'll all wear even / together / at the same rate. You might be able to loosen the rear axel slide the wheel enough forward to slip the chain off. Then clean & sand the sprocket enough to spray it whatever color you like. Then there's the problem of "over spray" on other parts of your bike...……………….If it were me, I'd do as Rebel said & just make whole sprocket match. You'll be the only person that'll ever notice it. But I understand wanting it to look like new, I'm the same way. Sometimes it worth all the extra work, sometimes it's not.
olegoat345 is offline
post #5 of 19 (permalink) Old 09-21-2019, 11:38 AM
I hope you realize that the sprocket gets very dirty quickly and nearly permanently. Your concern about this is silly. It's like being concern about keeping the tire tread clear and armoralled, it is insignificant. Spray it to even it out and call it a day.
Jroper likes this.
post #6 of 19 (permalink) Old 09-21-2019, 12:13 PM Thread Starter
mzflorida's Avatar
I have to tell you, I was entirely unaware of that recommendation to change all 3 at the same time. But makes perfect sense. Changes it from 40 bucks and a few minutes to 300 bucks and 4 hours. You are right. I will be the only person who will ever notice it. And it's my wife's bike. But, I think I am still going to try to find a way. I guess it is the military in me...clean, dry, serviceable.
post #7 of 19 (permalink) Old 09-21-2019, 12:39 PM Thread Starter
mzflorida's Avatar
Nope. Not silly at all. Yes, I do realize that the chain and sprocket become dirty very quickly. Part of the enjoyment I get from motorcycling is through the maintenance and improvement of the machine. Keeping them running and looking new gives me quite a bit of pride and enjoyment. That might not be part of why you are a motorcyclist, but it certainly does not make my choice silly.
post #8 of 19 (permalink) Old 09-21-2019, 01:01 PM
I would check to see if your wheel cleaner is safe for painted surfaces. The sprocket is probably permently stained or etched. Keep any kind of chemical cleaner from running down the sprocket directly into the rubber o rings of your chain. You could try some vinegar, metal polish or rubbing compound. A steel wool soap pad might also work. Last you could use a brass brush to polish the entire sprocket to a consistent finish. You wont get a perfect score at the Concours d'Elegance but the bright side is the more you ride it the sooner your going to have to replace it with a shinny new one. I have had o ring chains fail and bind up way before the sprockets were sufficiently worn and threw a new chain on them with no issues so I don’t subscribe to it is a must to change all three together. Ideally yes but mandatory no. Every situation is different.
https://www.harborfreight.com/5-piece-brass-wheel-and-brush-set-66114.html
2014 CTX700ND
dgall is offline
post #9 of 19 (permalink) Old 09-21-2019, 01:15 PM
If you're as anal as I am, you'll find away to make that sprocket look like new...
dgall has a few ideas you may want to try one of them.
I always figured that "wheel cleaner" had to be some strong stuff, I'd also bet It'll harm wheels over a period of time. My G/F uses it on her car wheels. I use car soap & a soft brush.
post #10 of 19 (permalink) Old 09-21-2019, 01:24 PM
Some ride and some polish....
It is an ugly sprocket to begin with, why not just get an aftermarket one while you are at it?
