Still waiting for fuel pump - Honda CTX700 Forum
 14Likes
post #1 of 18 (permalink) Old 07-22-2019, 02:44 PM Thread Starter
Athena's Avatar
Still waiting after two weeks for Honda to send a fuel pump to the dealer. Seems there has been a rush on fuel pumps (CTX) not sure why but beginning to wonder if they have been failing nationwide. Seen others on the site also having fuel pump irregularities.
CTX 700ND
Athena is offline
post #2 of 18 (permalink) Old 07-22-2019, 04:29 PM
dbmachine's Avatar
Saw a few post where bad gas was a culprit. I try to use nothing but the 91 octane non ethanol in everything if my local station has in stock.
2015 silver 700n dct abs
Kuryakyn boards
Mutazu bags
Clear lens
Led headlight
Led spot lights
Madstad kick pad
Grab grips
Fiamm horn
dbmachine is online now
post #3 of 18 (permalink) Old 07-22-2019, 05:25 PM
js52762's Avatar
I wonder if there are any aftermarket pumps on the market yet
js52762 is offline
post #4 of 18 (permalink) Old 07-22-2019, 07:21 PM
js52762's Avatar
There are pumps available aftermarket, but it is just the pump and not the whole unit. I guess it's an option if your only problem is the pump itself and not the level sensor, just take the unit apart and replace the pump, they run about $69, just putting the information out there
js52762 is offline
post #5 of 18 (permalink) Old 07-22-2019, 09:43 PM
Daddy Dave's Avatar
Wonder if Pro Caliber, would have them?
Daddy Dave is offline
post #6 of 18 (permalink) Old 07-23-2019, 09:56 AM
Question
Do you have any way of knowing if you inadvertently got E-85 ethanol gas, causing the problem/"meltdown"? Good luck going forward.
350Four is offline
post #7 of 18 (permalink) Old 07-23-2019, 10:48 AM
ctx man's Avatar
A good thing to remember is that the fuel in the tank cools the pump. Try to keep the fuel level from getting to low causing an early death for the pump.
Ruby and The_Bachelor like this.
Ride baby ride.
ctx man is offline
post #8 of 18 (permalink) Old 07-23-2019, 12:49 PM
Originally Posted by 350Four View Post
Do you have any way of knowing if you inadvertently got E-85 ethanol gas, causing the problem/"meltdown"?...
For the pump it does not matter what kind of liquid it pumps, if only the liquid's density is similar. But that matters to the fuel injectors and the engine.
Ares301 is offline
post #9 of 18 (permalink) Old 07-23-2019, 01:28 PM Thread Starter
Athena's Avatar
The pump is not just a pump but has a chip in it that reports back to the computer. If it were that simple to replace with a simple pump it would be nice, but as you know the CTX is heavily computerized. Perhaps a good and bad thing.
CTX 700ND
Athena is offline
post #10 of 18 (permalink) Old 07-23-2019, 01:30 PM Thread Starter
Athena's Avatar
There is E85 and E15 entering into the states. They are suppose to report the type on the pump clearly, but just as in the past when gas was diluted some are not so open. State weights and measures are suppose to check, but can't be everywhere.
CTX 700ND
Athena is offline
