Here's One for the Books - Page 3 - Honda CTX700 Forum
 25Likes
post #21 of 32 (permalink) Old 06-29-2019, 10:26 PM
Fuel stations HAVE had problems over the years with contaminates, wrong fuel in the supply tank, water mixed in and sometimes even completely wrong product put in their holding tanks.
I would check local news feeds and local forums for that station in particular. See if anyone else has had contaminated fuel of some sort recently. Stations that have issues (which usually affect dozens of customers) will often pay repair bills, so worth checking into.
My chemistry isn't the greatest, but I would guess the next most likely culprit would be the E85 others have mentioned. Not sure how it would dissolve parts though on two different bikes.
350Four likes this.
Thren is offline
post #22 of 32 (permalink) Old 06-30-2019, 10:13 AM
The pump is $358.27 retail and I think I could install one in about an hour @$100.00 per hour. Charge should be around $480.00. no more than $500.00 https://www.partzilla.com/product/ho...89c468bedb8478
2014 CTX700ND
dgall is offline
post #23 of 32 (permalink) Old 06-30-2019, 05:15 PM Thread Starter
Athena's Avatar
That's about right. But I also need to have the tank cleaned and scoured, new washers, bolts etc, injectors tested etc another 300 or so. Fuel lines flushed. This bad gas turned out to be very expensive deal.
CTX 700ND
Athena is offline
post #24 of 32 (permalink) Old 06-30-2019, 05:17 PM Thread Starter
Athena's Avatar
If it was E85 (not being used in Phoenix but who knows) then I have read about dissolving parts and warnings for other bikes. Apparently ok for new cars, but does the same for the older ones.
CTX 700ND
Athena is offline
post #25 of 32 (permalink) Old 06-30-2019, 05:23 PM Thread Starter
Athena's Avatar
Just my opinion but "the gas is literally eating away at the tank, and dissolved parts of the the fuel pump" is total BS.Please let us know what dealer is telling you this so we can avoid them in the future,
I had a chance to look at the parts. A complete disaster. The base of the pump and connectors are corroded, the pump shape is distorted and the tank has started to etch, . It looks like i put in a low level acid and not gas. There is also some sort of debris from the corroded parts. I wonder if someone is pushing E85 in town. Cars won't have much trouble but from what I read, this is a no no for most bikes. Apparently the same thing happened on the Harley so I don't think it is a coincidence.
350Four likes this.
CTX 700ND
Athena is offline
post #26 of 32 (permalink) Old 06-30-2019, 05:27 PM Thread Starter
Athena's Avatar
A little something on E85 15% ethanol. https://ethanolrfa.org/2013/06/ethanol-on-two-wheels/
CTX 700ND
Athena is offline
post #27 of 32 (permalink) Old 06-30-2019, 06:18 PM
DanIII's Avatar
No ethanol - E0
10% ethanol - E10
15% ethanol - E15
85% ethanol - E85
2014 CTX700N
2016 Street 750
2012 wide glide
2006 sportster
2002 Suzuki LC1500
1996 Suzuki 1400
1981 Suzuki GS650
1974 Suzuki TS250
1965 Honda CL77
1958 Cushman eagle
DanIII is offline
post #28 of 32 (permalink) Old 06-30-2019, 06:26 PM
Texas Roadrunner's Avatar
Personally I wouldn't even mess with that tank I would get on EBay and see if I could find all the parts. They've got lots of parts on there from low mileage bikes. You might save some$$$$. Hope this helps. I would probably look at new injectors also if its eating the tank it will eat the windings of the injectors. You might also check with your insurance company they might help.
Bryan
350Four likes this.
Texas Roadrunner is offline
post #29 of 32 (permalink) Old 06-30-2019, 07:17 PM
Question
One would think that others have the same problem, any chance the fuel seller will help $? If not, small claims court?
350Four is offline
post #30 of 32 (permalink) Old 06-30-2019, 07:26 PM
Just looked on EBay found fuel pump for $35 w/shipping, injectors and hose $47 w/shipping, fuel tank $66 w/shipping less than $150 for all parts not to bad.
Bryan
Daddy Dave likes this.
