Centerstand problem 2014 CTX DCT - Honda CTX700 Forum
 16Likes
LinkBack Thread Tools
Old 06-08-2019, 12:38 PM Thread Starter
Location: St. Marys, Georgia 31558 SE corner of Georgia
Recently bought and installed centerstand . I cannot get the bike to move up onto stand without first placing an piece of 2X6 board under rear tire and even then my weight 170#The bike is barely enough to get bike to roll up onto stand. Bike has original tires and is the Fairing model DCT. The bike was in NEUTRAL WITH PARKING BRAKE OFF. Came with Hepco-Becker instructions for mounting . Any suggestions or help appreciated. wvirnwkr
wvirnwkr is offline
Old 06-08-2019, 02:22 PM
mtvic's Avatar
Yep. Several of us were just not able to do it. The tire raises off the ground more than a factory center stand. Guess I need to bulk up. Anyway you'll hear all about Technics and rightfully so, but alas, some of us just can't do it.
Ruby and SpartaPanther like this.
2014 CTX700 dct
2016 NM4
mtvic is offline
Old 06-08-2019, 03:50 PM Thread Starter
thanks MTVIC for the reply---was hoping there was a technique that someone had discovered that I could try to to get the bike up without putting on extra body weight ---- perhaps making a longer removable/portable extension arm on the stand whjere you apply weight/foot pressure for more downward leverage. wvirnwkr
wvirnwkr is offline
Old 06-08-2019, 05:50 PM
I think i remember seeing a post where some one added a lifting strap where the passenger hand holds typically are, and that helped them.
Keep 2 Wheels Down, 73
Drey87 is offline
Old 06-08-2019, 06:33 PM Thread Starter
Thanks Drey87----- Since I ride solo I turned the left passenger footrest over so it is solid to use as a lifting handle but it did not help much maybe a strap or other gismo would help. wvirnwkr
wvirnwkr is offline
Old 06-08-2019, 06:35 PM
Post
Is your stand a Honda part from WeBike/Japan?
I think WeBike also sells a similar Honda centerstand, which is taller than the one being used by many of us, (& Too tall). On my stand, I have about 1.5" clearance under rear tire.
With my left hand on left grip, right hand on the passenger "handle", right foot moving centerstand down, I level the bike, begin to pull up slightly with my arms and, MORE Importantly, push my body weight downwards onto the stand, (then actually standing on it), kind of rocking the bike rearward in one motion. Body weight pushing down, does most of the work, arms do more just to guide the motorcycle. It helps to have long-ish arms and you must wear sturdy soled boots/shoes to avoid hurting your foot.
Make sure you have read about the weak mounting bolt supplied w/stopper, it is known to break. (btw; posting this without knowing who Hepco-Becker is)
EDIT: just found "Hepco-Becker" online. Appears to be a good product, method of using remains the same.
350Four is offline
Old 06-08-2019, 07:08 PM
i grab the saddle bag bracket and lift and step down....much...much easier than my old kawasaki concours....what i used with the kawasaki was a tapered board(more that 45 degrees if you can) ,placed it tight under the real wheel and that helped tremendously...some find leaning towards the rear and pulling(as was mentioned) on the handlebars(which need to be straight) aids in the process...i also make certain that the center stand is touching level on both pegs...practice on a flat and level surface and you'll get the hang of it
riderpat is offline
Old 06-08-2019, 07:55 PM
Texas Roadrunner's Avatar
I've got a easyup center stand for my Harley Ultra and with this stand I can put the bike on center stand with my wife sitting on the passenger seat with me straddling the bike. The best I can tell it's because the arm is longer that you step on, with factory Harley one it's as yall are saying it's extremely hard to lift.
I think if you would get a small peace of pipe to put over the arm that you step on it would help tremendously. I am posting a picture of the arm on my easy up stand it's 12 inches long from where it's welded to the stand to the end hope this helps.🤗
Bryan
Texas Roadrunner is offline
Old 06-08-2019, 11:32 PM
GonzoB's Avatar
wvirwkr,
two things:
1) did you get the right stand? It may be the wrong one, and too high.
2) assuming you did get the right stand, have you wound the preload on the rear suspension up all the way? As you have found out, it helps if the back of the bike is higher, and increasing the preload does that. Unfortunately, it also makes the bike lean more when it is on the side stand.
See the link in my signature - I ended up chopping 20mm off the legs of the centrestand, and it's really easy now. With the bike on the stand the tyre is about 32mm (1-1/4") off the ground, and on the side-stand with no-one on the bike the shock is at full extension.
Gonzo
GonzoB is offline
Old 06-10-2019, 09:40 AM Thread Starter
Thanks Gonzo and everyone who replied. Hepco-Becker stand is correct size. Tire is 1.25 inches off pavement fully extended. Must now increase rear shock spring to raise back of bike . Hopefully find a sweet spot for ride comfort and stand operation. The members and Forum are Awsome many thanks for your time and concern. WVIRNWKR
wvirnwkr is offline
Thread Tools
