Madstad Windshield - Advice Please - Honda CTX700 Forum
 3Likes
post #1 of 11 (permalink) Old 05-04-2019, 10:52 AM Thread Starter
jclar14's Avatar
Unhappy Madstad Windshield - Advice Please
I purchased a 22" Madstad windshield, and have had it on the bike since November last year. I may be experiencing some buyers remorse... and I'm wondering if anyone else has had similar issues, and if so whether anyone has any advice to resolutions... Here are my questions/gripes.
  1. The wind mounting has become loose twice where the two lowest well nuts have completely pulled through the opening under the cowling (the lower two closest to the headlight), I've had to remove the windshield and cowling twice, each time replacing the OEM wellnuts (90111-KW3-003). The top two mounts are fine, it's just the lower two. It seems like the wind pressure against the top of the windshield is pushing the top of the windshield back causing the bottom of windshield to push out. Any advice... I've re-installed twice, and it works for a while, but eventually well nuts keep pulling through the opening.
  2. The buffeting is horrible. I'm 5'-10". When I measured myself for the bike, I had to add an extra couple of inches because of the Corbin seat I have (it adds a couple of inches of seat height vs OEM seat). I have the 22" windshield, and have it set about 3/4" way up to max height. Top of windshield sits just above chin. It seems if I lower all the way, it's really bad (seems like my eyeballs are constantly rattling), the more I raise, the better it seems to be, but doesn't eliminate.
I invested quite a bit in this windshield... way more expensive than the factory OEM tall windshield, but these things got such great reviews. I'm finding it's bearable most of the time... but having to re-install the well nuts every few months is getting frustrating. I'm to the point I may just go back to OEM shorty windshield. If anyone has any advice... I'd certainly appreciate it.
Let's Ride...
Jason C
Carrollton, TX
jclar14 is offline
post #2 of 11 (permalink) Old 05-04-2019, 11:02 AM
mtvic's Avatar
First, put a washer on the underside of the mount (below) the slots/hole for the well nuts. No chance slipping through that way. In fact, MadStad mounted mine and that's what they did.
As far as buffeting... N model? seems more complaints for un-faired. You mentioned height, but you need to play with angle as well. I am on a faired and have the angle all the way down and even ended up putting shield in shortest position.
Also check where buffeting is coming from. May be coming from below and hitting you coming up. Move your legs around, move back, forward... change sitting position and try to locate where most of the buffeting is coming from.
Not sure if effective on the N, but the MadStad helped me so much for head on wind, I started to get buffeting from underneath which is why they now have "lowers."
2014 CTX700 dct
2016 NM4
mtvic is offline
post #3 of 11 (permalink) Old 05-04-2019, 11:03 AM
I’m sorry for the troubles you are having. I wish I had good news. My Madstad experience was awful too. Did not get too many miles to witness the mounting issues, but I would be deaf by now had I kept the C and the Madstad on it. It simply was awful.
-2013 Triumph Street Triple R
-2017 Honda CBR1000RR
-2018 Triumph Tiger XRx
-2019 Kawasaki Z900RS Cafe
Evangelos k is offline
post #4 of 11 (permalink) Old 05-04-2019, 02:27 PM
Adding washers to the bottom of the well nuts can help but the problem will always be too much weight and the added air pressure just over powers them. Tall CB windshields had the same problem. I got rid of the lower well nuts and replaced with bolts, washers, rubber washers, and nuts. This worked but was a PITA to tighten or loosen when doing maintenance. Eventually just tack welded washers in place on the lower mounts and that cured the problem completely.
As far as the buffeting, there are several things to consider. 1. If you have the older Madstad system, you need to replace the shield with the newer redesigned shield correctly sized to compensate for the 3" raised seat height. 2. Your shield height is not tall enough to compensate for the extra 3" in seat height the Corbin gives. You need a much taller shield or replace the Corbin with a Seth Laam seat. With your current shield height and setting, too much disturbed wind is flowing under and over the shield and then dumping into the cockpit instead of flowing up, over, or around you. The proper shield height should allow the shield to be lowered all the way down and angled back so the height is just about nose level to get the best performance. In your case, your probably about 3 - 4" off.
post #5 of 11 (permalink) Old 05-04-2019, 05:29 PM
bob witte's Avatar
For the record. Like Mike ( @mtvic ) cited above, I have a fairing edition of the MadStad system (including lowers) and I am more than satisfied.
bob witte is offline
post #6 of 11 (permalink) Old 05-05-2019, 06:54 AM
Jason,
At 50-55 mph, where does the wind blast coming over the top of the windshield hit you, or does it fly over the top of your helmet?
At 50-55 mph, where does the wind coming off the sides of your windshield go? Does it slip past your shoulders, or does it get sucked back in behind the windshield?
allen
allen framen is offline
post #7 of 11 (permalink) Old 05-05-2019, 04:31 PM
MadStad
Factory installed my Madstad with just rubber weldnuts.....
I removed rubber weldnuts and replaced with stainless machine bolts, flat fender washers, and nylock nuts.
That was three years ago and more than 10k miles...
No problems at all
No loosening
As sturdy as the day installed....by me
I did have them remake my windshield wider and taller then they originally used to make them based on their measurements....then the wind buffeting died down and I was happy.
This a test signiture
Danny W. Burdick is offline
post #8 of 11 (permalink) Old 05-05-2019, 04:49 PM
bob witte's Avatar
Originally Posted by Danny W. Burdick View Post
MadStad
No problems at all
No loosening
Danny, like @mtvic and myself, you have the fairing version. I think the MadStad problem he's have are for the naked system?
post #9 of 11 (permalink) Old 05-05-2019, 07:37 PM
The naked version doesn't use well nuts nor does it have a cowling. He's talking about the faired.
post #10 of 11 (permalink) Old 05-05-2019, 08:17 PM
bob witte's Avatar
Roger that, thanks for clearing that up.
