Motorcycle Kickstand Pad - Page 5 - Honda CTX700 Forum
 44Likes
post #41 of 64 (permalink) Old 04-17-2019, 07:15 PM
Professor said exactly what I would say. I really like the madstad pad. Great angle on the level now. No weird tilt. Thumbs up!
mtvic and david1954 like this.
2015 ctx700 faired dct
my other toys:
UNFORTUNATELY UNABLE TO BE IDENTIFIED
Mdaniels4 is offline
post #42 of 64 (permalink) Old 09-03-2019, 04:28 PM Thread Starter
BobbyD's Avatar
I ended up buying the eBay pad. It matched my bike perfectly, but it changed the lean angle when the kickstand is down from one extreme to the other ! I bought the pad for when I go camping and need to park on grass. The large footprint is perfect for that, but the 90% of the time when itís parked on hard ground it is a bit harrowing.
Well, the bike gently tipped over the other day as I was loading the left saddlebag. Fortunately, there was no serious damage and there was someone who gave me a hand to get it up right again.
A waste of money for the ebay kick stand! Is the Madstad better? Look at the pics of before and after install. Does it look like my kickstand is normal for this bike? Thanks.
BobbyD is offline
post #43 of 64 (permalink) Old 09-03-2019, 05:16 PM
TLeventry's Avatar
Your kickstand doesn't look like my kickstand....Are you sure someone didn't shorten it?
Professor*76 likes this.
Tony
2014 CTX 700N DCT
Kuryakyn Floorboards - Centerstand - Gonzo Shock Mod -Freeway Blaster Horns - Elcheapo Handguards - Madstad kickstand shoe - Madstad 22" Windshield - BrakeAway Cruise Control - Brake light flasher - Throttle Tamer - Oxford Heaterz - Riderscan Mirror - JFC Brackets - Michelin Road 5
TLeventry is online now
post #44 of 64 (permalink) Old 09-03-2019, 07:15 PM
That's what happens when you lower a bike! Do it right, shave the bottom-change the angle and weld a new foot on.
post #45 of 64 (permalink) Old 09-03-2019, 08:06 PM
Let's not confuse Communist and Socialist, they are nothing alike, not even close, except the "ist" on the end
Keco likes this.
olegoat345 is offline
post #46 of 64 (permalink) Old 09-03-2019, 08:47 PM
Keco's Avatar
Originally Posted by BobbyD View Post
I ended up buying the eBay pad. It matched my bike perfectly, but it changed the lean angle when the kickstand is down from one extreme to the other ! I bought the pad for when I go camping and need to park on grass. The large footprint is perfect for that, but the 90% of the time when it’s parked on hard ground it is a bit harrowing.
To me it looks like your stock kickstand foot doesn't set level on the ground, but at an angle. The new extended pad, being securely attached to the stock foot, has no choice but to sit at an angle. It's increased length serves to exaggerate the angle.
FWIW, I bought the Madstad pad at a "discount" when it first came out. I liked it, it appeared very well made and fit perfectly. I was satisfied until while at Americade in June, my fully loaded bike tipped over to the left, with the kickstand down, while in a parking lot. The top plate of the Madstad bent under the pressure and I had to remove it. When I got home, I tried to hammer out the top plate to flatten it, but it looked like crap and when I reinstalled it, the angle was off. It looked similar to your second picture above. I guess it's possible I bent the stock kickstand or its foot, although it still appears to sit flat on the ground without the Madstad installed. For $10 bucks, I'm gonna try the eBay foot.
Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts. Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime. (Mark Twain)
2014 CTX700e, 6 speed, white
Corbin low
Cee Bailey 23 w/vent
Shad SH36's
Shad SH50 trunk
Oxford heated grips
Kuryakyn 4357 foot board and 8815 splines
Denali DM Micro LED driving lights
Tutoro Auto oiler
Keco is offline
post #47 of 64 (permalink) Old 09-03-2019, 10:06 PM
What does that matter, neither are good, at all! Even in Marxist Theory (which by the way is the modern leading reason to support it) says: "Socialism is a transitional social state between the overthrow of capitalism and the realization of Communism."
Even in the slightly milder term of Socialism, why you want an authority to completely govern production, labor and sales? Have you been to an American supermarket? It doesn't get any better than that, it can only get worse! Show me one socialist state with a nation wide supermarket system that is better than the United Sates, you wont! Capitalism FTW
mario likes this.
post #48 of 64 (permalink) Old 09-04-2019, 04:05 AM
dbmachine's Avatar
Which pad are you getting from eBay? There are many of them on there
2014 candy red 700D dct abs
dbmachine is offline
post #49 of 64 (permalink) Old 09-04-2019, 07:13 AM
Keco's Avatar
DB, I think you're asking me. This is the pad I ended up ordering.
Corbin low
Shad SH36's
Shad SH50 trunk
Oxford heated grips
Tutoro Auto oiler
Keco is offline
post #50 of 64 (permalink) Old 09-04-2019, 08:32 AM
Yes
Well stated!
vb18 is offline
