Roxy Riser Install - Tip on brake line - Honda CTX700 Forum
post #1 of 1 (permalink) Old 06-18-2017, 10:25 AM Thread Starter
For those who do this here's a pic where to find bolt. Took me a while to find it. After, with a little wiggling the bracket will come off the hose. You can then Electrical tape protector casing across bare hose line for more protection and so lines won't catch. Then zip tie it tight again to bracket hole where you removed tie down holding electrical wire. Tip use 2 zip ties, wrap one around hose line the second through bracket and the one you put on hose. Pull tight after you see the amount of slack you want above and below it, this way you don't have friction on hose. Be forewarned, if you go for maximum pull back as I did lines will be a littler tighter than expected on full left and right handlebar moves. Maybe the moderator could take the original install thread, add this, and post it under Instructional Discussions.
2016 NM4
2014 ctx 700 dct
2012 Victory CCT - FOR SALE
Last edited by mtvic; 06-18-2017 at 02:45 PM. Reason: changing thread to help others
mtvic is offline
