Making it mine. - Honda CTX700 Forum
 33Likes
post #1 of 59 (permalink) Old 05-28-2017, 02:54 PM Thread Starter
Prgrmerror's Avatar
Making it mine.
I need a thread to help me get through all the mods I want to do. I'm going to have lots of foolish questions and I would like to keep this all in one place. Here are the planned mods. 2014 CTX700N.
Shad SH36 side bags
Tank pads
Windscreen
12v power point in the glovebox
Kury throttle lock
Cup holder for the bars
Centerstand and stop
Grip puppies
Thermometer
Prgrmerror is offline
post #2 of 59 (permalink) Old 05-28-2017, 02:59 PM Thread Starter
Prgrmerror's Avatar
First question... I removed all of the panels I think need to be removed so I can install the inner supports and 12v power supply. Am I supposed to remove the 4 bungee hook brackets or do they stay? Seems like they go for the 3P mounts but idk.
post #3 of 59 (permalink) Old 05-28-2017, 03:32 PM
Devilsfan's Avatar
Wow! You totally stripped that down! I may be wrong but I think for what you're doing all ya had to do was take off the seat (unless you're using the wiring harness) and maybe the two rear panels. The inner supports should go over the bungee hooks, then spacers then jfc's brackets, then grab bars.
Jimmy Hammond likes this.
post #4 of 59 (permalink) Old 05-28-2017, 04:53 PM
He's fine with what he did. The rear cowls have to be removed to install the inner supports. The right front side shelter needs to be removed when installing the OEM 12 volt socket/sub harness and makes it easier to run an after market 12 volt socket wiring. The bungee hooks do not need to be removed at this point. Best to wait and follow the directions when the time comes.
post #5 of 59 (permalink) Old 05-28-2017, 06:36 PM Thread Starter
Prgrmerror's Avatar
Thanks, I will add some pictures of the back of the right tank panel for future reference. I expect it's going to look this way for a week or 2. I did go with the oem 12v and wiring harness so yes I had to go this far. Also, if there are any recommended mods that require panel removal please let me know about them so I can consider before reassembly
Thanks
JH700CTX likes this.
post #6 of 59 (permalink) Old 05-28-2017, 08:00 PM
You're doing just fine....good to get it all done while you have that thing stripped down....
especially wiring...
Jimmy Hammond and Prgrmerror like this.
Danny W. Burdick is offline
post #7 of 59 (permalink) Old 05-28-2017, 09:18 PM
Grburkart's Avatar
Thanks
I'm in the process of gathering mods because I know the day is coming that I'm going to need to do exactly what you're doing now. These mods include a hard wired Navigation GPS system, running lights, GoPro wiring, electronics for a Scott chain oiler and a gear indicator. I have the 12 volt receptacle already installed but I don't want to use it up on the major electronics. Those are the mods I'm doing on the front end of the bike. The rear is just as challenging.
Glenn
JH700CTX and Prgrmerror like this.
Grburkart is offline
post #8 of 59 (permalink) Old 05-29-2017, 01:13 AM
Devilsfan's Avatar
How about a brake modulator? Since everything is off you may want to add one of those to the list.
Deeper6 likes this.
post #9 of 59 (permalink) Old 05-29-2017, 07:53 AM
The list never ends...hehehe
Stereo system with speakers
Wind shield
Center Stand
Seat upgrade
Luggage rack with backrest for passenger
Saddlebags
Top bag (trunk)
Usb and female lighter socket 12v
Running lights
Rear brake flasher (back off jack)
Throttle control from crampbuster to brakeaway
Hand protector covers
Deer whistles on front fender if you live with em
GPS
Drink holder
upgraded louder horn(s)
Luggage rack on top of trunk
Radiator guard
Backrest for driver
LED headlight bulb upgrade
numerous safety things...DOT reflectorized tape on sides and rear
More reflectors tag and front
Chain oiler manual or electrical
All these are on mine and I'm still shopping....LOL
My CTX So Far
post #10 of 59 (permalink) Old 05-29-2017, 09:57 AM Thread Starter
Prgrmerror's Avatar
This is what I was hoping for. That's some list. I have a Quardo Bluetooth in my helmet for tunes. There are a few I haven't thought about. When I think of upgrades I think comfort not safety or convenience. Modulator and chain oiler are a few; Thanks.
